orginal auspuff aufgemacht
Hi Jan Willem,
found a post on MaxSuz, that may help you. Cause only registered users have access to the tech support section, I´ll post it here as a quote:
Hi Dudes
Ok decided to mod my muffler along the lines of what I think Jesse does to the DR350 muffler.
I have chopped the round section of the muffler off and gutted it of the reverse baffle system and the perforated tube and sound deading material. I have also made a turned down 1.5 inch outlet for the end.
Now the inlet from the main body of the exhaust is approx 1 inch OD but is off centre by about 1.25/ 1.375 inch. So the question is should I port this pipe back over to the centre and straight out to the new turned down end cap I have made ( very fiddly), or should I just leave it which would mean that the round section of the muffler would act as a sort off expansion box. I do not think that the little extra back pressure that would be caused by this over porting it over and straight out would be significant?
If somebody that has jesse's muffler mod could do me the favour of poking thier finger inside the end cap and feeling to see whether Jesse pipes it over or leaves it open would clear thing up for definate (be careful as there may be a sharp edge).
TBH I think for the 50 Jesse charges for the mod, I find it hard to believe he goes to that much trouble. It would be nice to know for sure though if anyone could take the trouble to have a poke around smile.gif .
I hope to be welding it all back together Sunday depending on feed back from you guys.
DirtSquirt
Answer:
I just remembered, when I talked to Jesse about this modification,
he told me he uses a curved piece of pipe on the front end of the
modification. I assume it is in front of the baffle plates so I can't
see it. He also told me he pretty much guts the muffler and redoes
the entire inside of it.
I just rode my bike around the yard, it sounds real nice! Not offensively
loud at all. In fact, the throatier sound is less grating than the stock
wheeze that it used to have.
Hope this helps :zwinker:
Scholle
Beitrag von Scholle »
@Softstuff: nice! Ich denke mal, dass ich nen billigen Zweitauspuff besorge und an dem mal rumprobiere, nicht, dass i meinen originalen verkacke!
Danke für die Tipps! ;)
;) DR 350 Rulez! ;)
Ist doch nur Metall das kann man ja immer wieder zusammen braten wenn es nicht hinhaut :teufel:
Hajo
Beitrag von Hajo »
Muss jetzt auch noch was dazu loswerden. Hab im alten Forum glaube ich schon mal was darüber geschrieben. Ich hab das hintere Teil de original Dämpfer abgeflext und was dran hing "herausgerissen", dann hab ich das hintere Teil eines alten Honda XR500/600 Schalldämpfers abgeflext und drangeschweist. Sah absolut original aus. Das Beste daran war, das es ein Enstück war, welches einen Einsatz hatte den man nach Entfernen von zwei Schrauben herausnehmen konnte. Fragt aber bitte nicht nach dem Baujahr. Mit Einsatz ungefähr US Topf lautstärke, also gut für den TüV und ohne Einsatzt gerade noch IGE tauglich. Und auch da spürte man etwas mehr Leistung. Nicht nur Lautstärke.
donnar
Beitrag von donnar »
die dämpfer der xr600, xt 600 und tt600e und s haben auch diese flöte zum rausnehmen. sie dürften so ungefähr vom durchmesser her auch auf den dr dämpfer passen. ältere originaldämpfer bekommt man ja schon recht günstig.
