Carb Problem or not?
for our english-speaking guests - english only. The place to discuss any DR350 specific technical / mechanical /repair / preparation questions you like, or answer others questions if you can.
offroad
Beitrag von offroad »
I have a Dr 350 97 Sev. eveything is stock.the air filter is K&N typ Papper.The problem is that when the bike is accelarating at around 4.500 / 5000rmp. it will die if I dont up a gear.If I up a gear there is no problem. if I dont the bike dips its head and if I hold the accelator with out moving it the bike will pick up gradualy.This is a real pain when I am overtaking cars. If I shift gear around 4000rpm the accelaeration is not fast to overtake quickley.
Some say its an electronic limiter??.
Does any one have an idea what this can be.
The carb has been striped and cleaned still the problem is there.
Thanks
GEROLO
Beitrag von GEROLO »
Hello,
I don´t think that it is a electronic limiter.
A limiter (the name say it) limits the revs but it doesn´t stop the engine.
How exactly does the engine die?
Is it like it will get not enough fuel?
Than you have to look why.
- is the filter on the gas cock clean?
- does the tank ventilation work?
- is the float in the Carb in the right position?
hope it will help
Gerold
offroad
Gerolo Thanks for the reply.
the engine dies as if it is getting too much fuel.?f I keep the accelerator in the same position when it dies the engine slowly starts to pick up.as it burns the fuel.
When it D?ES it does not completly stop. but it stops accelarating / burning fuel it is as if the engine is getting toomuch fuel and is choking.
This dos not happen when the engine is above 5000 revs.
is the filter on the gas cock clean? YES
- does the tank ventilation work? yes
- is the float in the Carb in the right position? What position is the correct one?
Mitglieder in diesem Forum: 0 Mitglieder und 12 Gäste
