I've seen this beautifull site so i decide to register and here i am:
I've a 1992 Suzuki DR 350, it's like new, it has 12.000 Km and it's yellow frame model, i changed carb with a Mikuni TM36, K&N filter, Hot Cam, hard faced rocker arms, and a complete exhaust system from America brand PRO-CIRCUIT.
It's terrible!
But i have a big problem with clutch: i know it's a very very usual problem on this bike but now i can't drive it because with the 1 gear engaged it goes on and it's not possible to drive...
A month ago i changed clutch (with a complete clutch kit brand EBC) because i always had difficulties finding N, so i thought clutch was arrived in service limit...
but once desassembled, i measured old clutch and it was all in perfect working conditions.. but after all i decide to install new clutch....not only problem didn't disappeared but also NOW with clutch lever pressed it goes on! worse than first!!!
I've seen all reports and tricks about clutch change on DR and i'm sure i made a good job, i also disassembled clutch basket: it's not bad but it has wear signs inside it.
I also tried to change oil, from a 10W-40 to a 5W-40 but nothing changed.
I can't understand what it's appening
Please if you had problems like me help find a solution because i'm depressed..it's a pair of weeks i'm working on it but i still have no improvement
